Change color of line
4 messages Options Options
tony4693
Hi, i should change color and thickness of some lines of a .dmf file tom white to blue/red/green.
I try to select one single line and  click modify->properties->color. The color changes but when i open the preview or i export to pdf the lines are all black (only thickness is correct). Thanks in advance
Re: Change color of line
Please use 2.0.7 or the latest git version, and make sure you use "File -> Export as PDF" instead of the "Printing to file" option from the Printer Dialog.
tony4693
Yes i have the 2.0.7 Maverick version and i've already try to export to pdf but nothing. The lines are still black.
Could be a bug?
just tested the latest master branch for "Export as PDF".
Color, line type, line width properties are all shown in exported PDF
On OSX 10.9.5
