I completed my drawings, but I started them at the absolute zero point, so printing it misses the l.h.s. lines and dimensions.
Is it possible to move the A.Z.P. or move the drawings away from it?
Cheers.
In the case where there are two drawings on a page, is it possible to move one independently from the other, i.e. to slide one part over the other, temporarily?
You can't do it in Print Preview, if this is your question.
In drawing mode you can select one part with pulling up a window around it, and move it with the Move tool.
To avoid the problem aman mentioned it is helpful to transfer the moved part to an extra layer. Select with window, Tools - Modify -Attributes.
Or be sure the drawing is saved at last state before moving, then after moving make an Undo or just close the drawing and reopen it.
Thanks again, it sounds like if I want to have the ability to superimpose one drawing over another for a visual, before returning it to its place, I should make each drawing on a separate layer from the outset?
Cheers.
