I have to pick up this topic again as I still have no solution.
@Jaycad, I cannot reproduce your suggestion.
I tried the following:
1. Switch to layer 0, import an object from the library, change the layer via "properties" of that object to my "colored" layer. => no effect. Object still white.
2. Switch to layer 0, change color of layer 0 to the same color as my colored layer, import an object from the library => no effect. Object is still white.
I can confirm that "exploding" leads to a change in color. But I want my objects to be a single object. And if I understand it correctly, there is no "grouping" function as an opposite to "explode". Correct?
