First of all I suggest someone of the admins to add a sticky thread under librecad-dev so that anyone who wants to find/add an compilation issue , he/she can put it in a specific thread. That way all compilation issues are in the same place.
So my problem now, i forked the git librecad repo and then cloned it to my pc (ubuntu 14.10). Then i tried compiling it but qtcreator complains about a module: Project ERROR: Unknown module(s) in QT: help I tried looking at google I also tried at #librecad chat room but no luck. I was suggested to add some libraries which i found out that were already installed. Then i found out this one http://riesvantwisk.com/cms/home/irc-logs/librecad-irc-log/2014/June/29.html which seems to be more or less the same problem with mine. I followed it again with no luch. I am not able to compile in qtcreator. However i found out that i am able to compile from the terminal using make (???). Has anyone any idea what is wrong with my qtcreator? Any suggestions? Thank you in advance. Nikos |
In reply to this post by kosnick
Good idea!
in ubuntu, please try to get compiling dependecy by: $ sudo apt-get build-dep librecad in this qt-help dependency, please try: $ sudo apt-get install libqt5help5 libqt4-help Please also help with wiki: http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD_2.0_on_Linux
Actually, we are still using qt-help in a trivial way.
From Help ->Manual, a page is shown to say we have no manual, and several URLs are given.
both modules dxli is suggesting are in newest version.
also the page dxli is suggesting has nothing new for my case, i mean i had done each and every one of the steps. To make sure though i repeated the apt-gets there with no luck, everyone already installed to newest version. To make thing clear, i am able to use make to compile. I can not compile (or run) through qtcreator. |
let's try to clarify:
does it build for you from cli? $ qmake -r $ make if cli builds for you, but qtcreator does not. Try to fix kit/tool chain in qtcreator.
Can you please check, if you have missed to uncheck Shadow build Option after configuring project in QtCreator.
You find this in the Project view, Build Settings -> General Armin
I believe my issue has been solved.
As suggested, it was something with the kits. I added the second one (qt 4.8.6 system) from Projects views and then the Add kit button. Shadow checkbutton deselected and ... that's it. In the first kit i tried deselecting the shadow checkbutton but it didn't work. so now its something like this: general: shadow build checkbutton is NOT checked build directory is set to where the project is (default value, i didn't change anything there) build steps: qmake: qmake-qt4 librecad.pro -r -spec linux-g++ CONFIG+=debug make: make in the same as build directory clean: make clean in the same as build directory thx for helping me out |
I think qmake (qt5) works also.
When you feel comfortable, please help adding our building wiki.
