Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
First of all I suggest someone of the admins to add a sticky thread under librecad-dev so that anyone who wants to find/add an compilation issue , he/she can put it in a specific thread. That way all compilation issues are in the same place.
So my problem now, i forked the git librecad repo and then cloned it to my pc (ubuntu 14.10). Then i tried compiling it but qtcreator complains about a module: Project ERROR: Unknown module(s) in QT: help I tried looking at google I also tried at #librecad chat room but no luck. I was suggested to add some libraries which i found out that were already installed. Then i found out this one http://riesvantwisk.com/cms/home/irc-logs/librecad-irc-log/2014/June/29.html which seems to be more or less the same problem with mine. I followed it again with no luch. I am not able to compile in qtcreator. However i found out that i am able to compile from the terminal using make (???). Has anyone any idea what is wrong with my qtcreator? Any suggestions? Thank you in advance. Nikos |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Nikos, do you have Qt Help installed? However, top od my head (dli knows) we are not using Qt Help anymore. Ries
... [show rest of quote] |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by kosnick
Good idea!
in ubuntu, please try to get compiling dependecy by: $ sudo apt-get build-dep librecad in this qt-help dependency, please try: $ sudo apt-get install libqt5help5 libqt4-help Please also help with wiki: http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD_2.0_on_Linux
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Actually, we are still using qt-help in a trivial way.
From Help ->Manual, a page is shown to say we have no manual, and several URLs are given.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
both modules dxli is suggesting are in newest version.
also the page dxli is suggesting has nothing new for my case, i mean i had done each and every one of the steps. To make sure though i repeated the apt-gets there with no luck, everyone already installed to newest version. To make thing clear, i am able to use make to compile. I can not compile (or run) through qtcreator. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
let's try to clarify:
does it build for you from cli? $ qmake -r $ make if cli builds for you, but qtcreator does not. Try to fix kit/tool chain in qtcreator.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Can you please check, if you have missed to uncheck Shadow build Option after configuring project in QtCreator.
You find this in the Project view, Build Settings -> General Armin
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I believe my issue has been solved.
As suggested, it was something with the kits. I added the second one (qt 4.8.6 system) from Projects views and then the Add kit button. Shadow checkbutton deselected and ... that's it. In the first kit i tried deselecting the shadow checkbutton but it didn't work. so now its something like this: general: shadow build checkbutton is NOT checked build directory is set to where the project is (default value, i didn't change anything there) build steps: qmake: qmake-qt4 librecad.pro -r -spec linux-g++ CONFIG+=debug make: make in the same as build directory clean: make clean in the same as build directory thx for helping me out |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I think qmake (qt5) works also.
When you feel comfortable, please help adding our building wiki.
