Compiling LibreCAD with Visual Studio 2010
corecible
These days ,I  compiled LibreCAD with Visual Studio 2010,
I encountered some problems:Visual Studio 2010 does not support C++99,such as
class RS_FileIO {
private:
    //singleton
    RS_FileIO();
    RS_FileIO(RS_FileIO&) = delete;
    RS_FileIO& operator = (RS_FileIO&) = delete;
these process ,I solved the following problems:
msvc complains that more than one overloaded functions matches:
std::ofstream << (double) x;
msvc complains that it could match both of the following:
std::ofstream << double
std::ofstream << long double
just noted these codes:
inline ofstream& operator<< (ofstream& ofstr, const DWORD& output)
        ofstr.write((char*)&output, sizeof(DWORD));
    return ofstr;
inline ifstream& operator>> (ifstream& ifstr, DWORD& input)
        ifstr.read((char*)&input, sizeof(DWORD));
    return ifstr;
inline ofstream& operator<< (ofstream& ofstr, const WORD& output)
        ofstr.write((char*)&output, sizeof(WORD));
    return ofstr;
inline ifstream& operator>> (ifstream& ifstr, WORD& input)
        ifstr.read((char*)&input, sizeof(WORD));
    return ifstr;
inline ofstream& operator<< (ofstream& ofstr, const BYTE& output)
        ofstr.write((char*)&output, sizeof(BYTE));
    return ofstr;
inline ifstream& operator>> (ifstream& ifstr, BYTE& input)
        ifstr.read((char*)&input, sizeof(BYTE));
    return ifstr;
inline ofstream& operator<< (ofstream& ofstr, const int& output)
        ofstr.write((char*)&output, sizeof(int));
    return ofstr;
inline ifstream& operator>> (ifstream& ifstr, int& input)
        ifstr.read((char*)&input, sizeof(int));
    return ifstr;
class String {
 private:
        char* data;
        size_t size;
 public:
        String(const char* str = 0)
                if( str ){
                        data = new char[strlen(str)+1];
                        strcpy(data, str);
                        size = strlen(str);
                }else{
                        data = NULL;
                        size = 0;
        ~String()
                if(data)
                        delete data;
                size = 0;
        char* ascii(){return data;}
        int length(){return size;}
        String& operator=(String& str)
                if(str.length()==0)
                        return *this;
                if(data)
                        delete data;
                data = new char[str.length()+1];
                strcpy(data, str.ascii());
                size = str.size;
                return *this;
        String& operator=(char *str)
                if(strlen(str)==0)
                        return *this;
                if(data)
                        delete data;
                size = strlen(str);
                data = new char[size+1];
                strcpy(data, str);
                return *this;
        friend inline ofstream& operator<<(ofstream&, const String&);
        friend inline ifstream& operator>>(ifstream&, String&);
        friend inline ostream& operator<<(ostream&, const String&);
        friend inline istream& operator>>(istream&, String&);
inline ofstream& operator<< (ofstream& ofstr, const String& output)
        ofstr.write((char*)&(output.size), sizeof(size_t));
        ofstr.write(output.data, output.size);
        return ofstr;
inline ostream& operator<< (ostream& ostr, const String& output)
        return ostr << output.data;
inline ifstream& operator>> (ifstream& ifstr, String& input)
        ifstr.read((char*)&(input.size), sizeof(size_t));
        input.data = new char[input.size+1];
        ifstr.read(input.data, input.size);
        input.data[input.size] = (char)NULL;
        return ifstr;
inline istream& operator>> (istream& istr, String& input)
        const int maxline = 512;
        char holder[maxline];
        istr.get(holder, maxline, '\n');
        input = holder;
        return istr;
Re: Compiling LibreCAD with Visual Studio 2010
hi,
please supply a patch or a pull Request by GitHub.
thanks!
class RS_FileIO {
private:
    //singleton
    RS_FileIO();
    return ofstr;
    return ifstr;
    return ofstr;
    return ifstr;
    return ofstr;
    return ifstr;
    return ofstr;
    return ifstr;
class String {
 private:
        char* data;
        size_t size;
 public:
                if( str ){
                        strcpy(data, str);
                        size = strlen(str);
                }else{
                        data = NULL;
                        size = 0;
        ~String()
                if(data)
                        delete data;
                size = 0;
                if(str.length()==0)
                        return *this;
                if(data)
                        delete data;
                size = str.size;
                return *this;
                if(strlen(str)==0)
                        return *this;
                if(data)
                        delete data;
                size = strlen(str);
                strcpy(data, str);
                return *this;
        return ofstr;
        return ifstr;
        input = holder;
        return istr;
