Convert dwg to dwfs files
Daniela
Hello everyone,
It is possible with this program convert the file dwg in a new file dwf?
Re: Convert dwg to dwfs files
DWG support is still not perfect in LibreCAD, so even import could be challenging.
DWF is no file format that is supported by LibreCAD. LibreCAD can write DXF, SVG, PDF and some pixel image formats.
Fredevans
I have been trying to do the same thing
I downloaded a file from teigha which is a dwg to dxf convertor .
i ran the file and it converted a simple file quite nicely.
the file i downloaded was version 4.3.2
regards from south africa
Habe77
In reply to this post by Daniela
yes but many trouble ,file dwg convert use inkscape , layer ok can read
I'm in the process of improving dwg support in LibreCAD (and libdxfrw), but the changes will be in the master branch (2.2.2_alpha), not targeting stable release yet (2.2.1.x)
