Copy command
Copy command
ChadHenard
I am trying to copy and object, but when i select the object and asks for a reference point it just back out of the command and will not let me specify the reference point or the desired location.
Re: Copy command
sand1024
which version of LibreCAD do you use? which operating system?
Re: Copy command
ChadHenard
I am using version 2.2.0.2 on windows11.
Re: Copy command
After having applied the Copy command then use the Paste command to insert the object.
Alternatively you can use Move/Copy from Tools - Modify. This behaves the way you expect.
Re: Copy command
ChadHenard
Thank you. That is what I ended up doing is using the move command get the desired outcome.
