Copy paste problem in LibreCAD-v2.2.1.3
9 messages Options
onur
I just install LibreCAD-v2.2.1.3 and copy paste works not expected. Pasted objects always much smaller than original. I downgraded to LibreCAD-v2.2.1.2-14 and its working as usual.
To reproduce just draw a circle and try to paste it to the same drawing.
Thanks.
onur
Re: Copy paste problem in LibreCAD-v2.2.1.3
I will look into this one.
Looks like 2.2.1.4 is expected sooner than expected.
Thanks.
onur
In reply to this post by onur
hi onur,
could you provide detailed steps to reproduce this issue?
Tools > Modify > Move/Copy works smoothly here.
Thanks.
onur
onur
hi dxli,
Sorry, I should have done that in the first place. You're right. MOVE/COPY command works correct. I was using Copy(CTRL+C) and Paste(CTRL+V) from Edit toolbar.
I'm new to CAD and LibreCAD, so sorry if this is a rookie mistake.
Ctl-C/Ctl-V needs some fixes.
@sand1024, just wondering whether you can look into this one.
2.2.1.4 should be released after this one is fixed.
onur wrote
hi dxli,
Normally Copy(CTRL+C) current object, use can move (even to different application), and Paste(CTRL+V).
First impression feedback is great, obviously regular users can't do it.
I have fixed Ctl-C/Ctl-V in 2.2.1 the branch. The 2.2.1.4 release is expected soon.
onur wrote
hi dxli,
onur
Hi Dongxu Li,
I've test this release, and still get much smaller copy of the original object.
Version: v2.2.1.3-4-g35be9afde
Compiler: Microsoft Visual C++
Compiled on: Jan 24 2026
Qt Version: 5.15.2
Boost Version: 1.87.0
onur
Still not working on latest release on windows.
