First I would look if the PlasmaCam software really can't accept mm. Even if it's from USA I would be surprised. I would expect there is a possibility to switch to mm somewhere.
If not, 1 inch is 25.4 mm. So you have to scale down the drawing in LibreCAD. Tools - Modify - Scale, in the input box write "1/25.4" for the scaling factor. Just to change the units to inch is not enough, the drawing is not being scaled automatically.
