You can't change the properties of just a part of a line and still have it to be one entity. You have to break it up. Tools - Modify - Divide is the proper instrument for this. Select the line and then select the cutting point, probably an intersection, with snap intersection on. You can only do one cut per operation. Then change properties of the desired part. Maybe not less work than trimming and redrawing.
