DXF library query
DXF library query
Devinder Kaur
I have been working on DXF files, their generations and other related stuff like providing its support to a particular CAD software. While digging the related stuff on web I come across to the following thread:
http://forum.librecad.org/LibreCAD-DXF-File-Structure-td5707695.html
As mentioned in this, we can make use of the following already existing library and ease off the work.
https://github.com/LibreCAD/LibreCAD/tree/master/libraries/libdxfrw
I want to clear my query that whether I could use this same source for my own CAD software without any license issue or I have to work for a new one?
Re: DXF library query
Devinder Kaur
On Thu, May 15, 2014 at 7:03 PM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote:
> Hi,
<snip>
> This depends on the license of your own CAD software. If it’s GPLv2 or
> higher licensed then it’s not a problem to use libdxfrw.
> If you have any other license model you have to check if it’s compatible
> with GPLv2 or higher of not, you are not
> allowed to use libdxfrw.
Actually am working on a software named DR. Geo under GNU for
GSoC2014. Check it here:
https://savannah.gnu.org/projects/dr-geo
We are currently working on the first version of it, which is having
many loop holes and lack of dxf support is one of them. Which I am
intended to fulfill as one of my GSoC milestones.
> Also, please be aware that some licenses are to take in a other type of
> license, but not the other way around.
> For example, it’s fine for a GPLv2 application to use a MIT library,
If am not wrong Dr. Geo is under GPLv2.
> it’s not allowed the other away around.
And what could possibly be the other way around? Though I have gone
through http://www.gnu.org/licenses/licenses.html but I would like to
make it more clear form you.
> not a lawyer, so don’t hang me up on what I just said, check with your own
> lawyer to make sure.
:p
> If you are making a open source CAD application, why not help us out!!! :D
Yeah, soon I ll be working on that too. It would be my pleasure! :P
> Feel free to contact me if you have any further questions
Sure! Thanks for the cooperation. :)
"Today, its a beautiful day, So live your dream. "
http://devinderkaur.wordpress.com
Devinder Kaur
Devinder Kaur
On Fri, May 16, 2014 at 11:36 PM, R. van Twisk [via LibreCAD]
> hello Devinder,
> Since Dr Geo is licensed GPLv2 or higher you don’t have to worry about
> license issues when you are using libdxfrw,
> so that solves are you problems!
> If I am not mistaken, the official repo is located here :
> https://sourceforge.net/p/libdxfrw/code/ci/master/tree/
> Good luck on your GSoC project this year!
Thanks a lot for your response. Now I can continue with my further
work. But I would be concerning you in the future too as I ll be
digging the code soon. :P
Devinder Kaur
