please find a detailed procedure to reproduce this bug, like:
1, Draw -> Line 2 points: draw line from 0,0 to 1,1
2, Modify -> Mirror: select the line drawn in step 1 to make a mirror, and click the right Arrow in CAD toolbar or press Enter to continue;
3, select the first point on mirror line: 1, 0
4, select the second point on mirror line: 1,1
5, in mirror dialog, choose "Keep Original", and Click Ok
expected result:
a mirror of line drawn in step 1 is created.
It also helps to attach a test case DXF file to show this bug.
I removed some overlap as shown in:
cleanup.dxf
Lumaja wrote
OS Ubuntu 12.04
LibreCad
LibreCad 2.07
GNU GCC 4.6.3
Qtver. 4.8.1
After mirroring a drawing and realise I left a line too long, tried to trim but with Trim command on and click on the line doest not change to the correspond colour, the Delete, add a line or a circle command does the same.
I made a line and a cross on the same page I can Delete or Trim.
I think since I mirror the drawing it is is locked to any Editing
