Probably an example of bug turning into feature
Travis S wrote
I have found a work around for snapping to dimensions.
You can use Snap Distance and then make the distance 0.
This allows you to snap to the ends of any dimension lines.
For snapping to the lines with an arrow hover over the line just behind the wide part of the arrow. The cursor will snap to the end of the line.
This also works for leaders as well.
It even allows you to snap to any straight lines of the numbers themselves.
