Dimension tolerancing
1 message Options
ml-node+s1049103n4499514h46@n5.nabble.com
I am trying to specify several dimensions in my drawing, but it does not seem that it is possible for two reasons
1) The dimension tolerance under edit->current drawing preferences->units->precision seems to be not used for the tolerances (perhaps for underlying calculations? - there is not tooltip for what this means on the value)
2) It does not seem to be possible to set dimensions per-dimension. Some dimensions should in reality have different tolerances to others.
Currently the drawing seems to only use integer values for the tolerancing. I use LibreCAD rarely (as I do not often need to do CAD work),  but I recall that I was able to get around this before - but I cannot work out how I did it last time!
Any help is much appreciated - I am using 1.0.1 from (1.0.1+nolibs-2, under ubuntu 12.04).
