Dimensions in form of:
1, vertical/horizontal, measures the distance in the corresponding directions; Those two types can be created by "Linear Dimension" also (check the toolbar options to switch between horizontal/vertical);
2, aligned dimension: to measure point-to-point distance and draw dimension aligned.
in you dxf:
31.026 is horizontal, so distance is only by the horizontal direction;
31.454 is aligned, so distance is point-to-point, which is larger than its horizontal component (31.026)
JDelgado0311 wrote
I created this file to show the issue. I was trying to create an object 4x6x24 inches. I'm noticing that the 90 degree lines distance out as I expect them to. The lines that are sloped do not. I'm wondering if I should be taking into consideration what the angle of perspective is doing to the offsets"
Thanks in Advance.
dimensioning.dxf
