Dimensions displacable ?
3 messages Options Options
newbee1
1 post
Hello everybody,
i have the problem, that i do dimensions on circles, but
some also with a center cross-hair.
So then the dimension is printed in the center of the
dimension-line. But here it will be cut by the cross-hair
of circle center.
Is there a possibility to move the dimension Text on the line?
Thank you in advance,
regards,
newbee1
Re: Dimensions displacable ?
in default action, you can click the dimension text to get the reference points, i.e., if you end all actions.
1, click "Selection Pointer" button in top toolbar area.
2, click the dimension entiy;
3, click and drag to dimension text reference point shown to move the text.
Re: Dimensions displacable ? [SOLVED]
newbee1
1 post
Hello dxli,
thank you so much.
This is wonderfull and works perfect.
Best regards,
newbee1
