Hi dellus,
Your suggestion to use the “Fractional Format does help,
I do not need the “crowfeet” (“) to know I am working in
inches.
Thanks again,
AK
in regards to “ Isotropic “
a post back in 2014, suggested the following
steps:
 1. open drawing 2. Edit current drawing preferences and set the
precision as high as possible. 3. Edit current drawing preferences and set
dimension main units to inch and length to architectural again setting the
precision as high as possible. 4. Modify -> Scale 5. Select all 6.
Isotropic Scale  12 7. Reset the precision to your desired amount.
Sent: Tuesday, October 29, 2019 11:36 AM
Subject: Re: Dimensions
Just
played around, found that with Linear units = Fractional all zeros are gone, but
also the inches ''. Don't know if this serves you. Don't know much about the
imperials system anyway.  What is the isotropic method?
