Dimensions
Dimensions
roberto fabbri
Hello everybody.
I'm new on this forum. My name is Roberto Fabbri.
I have problems with the dimensions: I followed the instruction manual, but the only result I had above the line with the two arrows is an empty rectangle without any text inside.
What I'm mistaking?
Thank you very much in advance for any help you can provide me.
Roberto
Re: Dimensions
Polgi
Hi Roberto,
I think you can find the answer here:
https://forum.librecad.org/Dimensions-without-dimension-td5716276.html#a5716283
I had the same problem, and I switched the Draft mode and I could see the dimensions number
Re: Dimensions
roberto fabbri
Hi Polgi.
Thank you very much.
I'll give a look to the link immediately.
Cheers
Roberto
Re: Dimensions
roberto fabbri
IT WORKED!!!
Thank you very much again, Polgi!
I was struggling with this problem since a long time and you have no idea of the relief I'm feeling.
As you can imagine a draw without dimensions is totally unusefull.
You've been of great help, really.
All the best for you.
Roberto
