how can i use more FONTS (ttf)
13 messages Options
gabriel
i have installed more fonts in my computer than those showing up in the "text tool" should i copy them into a specific folder? i havent really look into it very deep, hope anyone can help, thanks.
im running Ubuntu 11.10
Re: how can i use more FONTS (ttf)
True type fonts are not supported in LibreCAD, only stiky fonts.
If you want to use ttf you can first convert it to lff fonts and add
the path in "Edit->application preferences" tab "paths"
gabriel
thanks, i looked a little deeper and got figured it out, i will try the conversion way, if i get it rigth ill let you know, because ill try to convert several "architectural" fonts to lff.
if the fonts are licensed by free software licenses, we would like to include them in the LibreCAD package.
gabriel
they come from dafont.com, one is donation, so that one is a no no, the other one is free, so that is a go.
i found Rallaz convertion tool ttf2llf but could not do anything with it, tried to run it (Ubuntu 11.10 64b, im a noob) but did nothing at all, tried running it in a terminal (Ctrl+Alt+t) also nothing, found Font Forge (Ubuntu Repositories) but is no longer available, went to the developer web page and tried to download and install but couldnt, so im stuck for the moment, ill keep on trying, let you guy know in a couple of days.
Soy Yo
http://librecad.1049103.n5.nabble.com/how-can-i-use-more-FONTS-ttf-tp5483251p5485879.html
Gabriel,
In a caonsole:
ttf2lff /path_to_ttf_file/font.ttf /path_to_new_file/fontt.lff
/*Spanish*/
En consola:
ttf2lff /ruta_a_archivo_ttf/fuente.ttf /ruta_para_el_nuevo_archivo/fuente.lff
gabriel
sorry Rallaz but i lost the ttf2lff script, could you post a link to it? i cant find it on the forum nor on IRC, thanks in advance.
This is a version compiled for openSUSE 64b and I suppose that work in ubuntu:
http://sourceforge.net/projects/rallaz.u/files/fontconverter/ttf2lff-linux-x86_64.zip/download
gabriel
thank you Rallaz, here i go again to try and convert a couple ttf's.
Soy Yo
On Sun, Mar 4, 2012 at 6:09 AM, Rallaz [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/how-can-i-use-more-FONTS-ttf-tp5483251p5535116.html
Zhao Zhichao
  Hello,my teacher Rallaz,how can we convert a file of ttf to lff under Linux system?
I get the LibreCAD for Linux and run the tools.pro,while,a Linux terminal is actived.
Hi Zhao Zhichao,
You can't run tools.pro
Download ttf2lff-linux-x86_64 form my previous post and run in a console:
ttf2lff input.ttf output.lff
This program is for 64 bits arch.
If you want to compile it then
cd tools/ttf2lff
qmake ttf2lff.pro
make
if you have more questions indicates which is your system and architecture (32 or 64 bits)
in the next version (2.1), we have to support using Qt fonts.
wade ryan
I tried converting the google font OpenSans by Steve Mattenson using ttf2lff, but the lower case r is definitely not right, so I'm assuming either I'm doing something wrong or the ttf2lff program isn't working quite right.   I would greatly appreciate if someone could work on converting this to work with LibreCAD and hopefully it could then be included in the next LibreCAD release as it is free to use.
