Dimensions will not offset from entity line
5 messages Options Options
Tnemmo
This post was updated on Jan 22, 2023; 3:10am.
Re: Dimensions will not offset from entity line
First, I changed the title, because it was too loud.
Probably just a snapping issue: https://forum.librecad.org/Cursor-control-tp5722294p5722308.html
Tnemmo
LordofBikes,
Thanks for the suggestion. I checked this, and none of the snapping restrictions was turned on. I have only the "free snap" and "snap end points" turned on from the snap menu.
Do you have realized you have to specify the dimension line location with a third click after the origin points? Move farther away from the base line to see if it works. If it works only too far from the base line for your liking then zoom in narrower.
You also can move, reposition an existing dimension line by clicking on it and then grab it at the small blue rectangle at one end and drag it to the desired position.
Tnemmo
Thank you for the reply. l finally gave up and uninstalled, then reinstalled the program again. Now it is working fine. Perhaps it was a bad installation to begin with, or the setting causing the problem was reset in the new installation.
Maybe an uninstall and reinstall of the program could be one of the resolutions for his issue. t worked for me.
