Download LibreCAD for Windows.
6 messages Options Options
K Lowe
This post was updated on Apr 29, 2015; 9:32am.
Re: Download LibreCAD for Windows.
claus82
Here
See ya!!!
http://sourceforge.net/projects/rallaz.u/files/librecad-win/librecad2.0.0beta1-git2013-04-16.7z/download
K Lowe
1 post
I appreciate your reply.
The LibreCAD Home page "Download LibreCAD for Windows" link is for version "LibreCAD-Installer_2.0.0beta1.exe 2012-10-30", and the above download link is for version "librecad2.0.0beta1-git2013-04-16.7z".
However, both versions are "LibreCAD2.0.0beta1" for Windows. Is there a version "LibreCAD2.0.0beta2" for Windows, as mentioned on the News page.
Thanks for any help.
I tagged 2.0.0beta5, need to build installer files
Would it help if I create a screencast on how to build the installer files for you and rallaz?
We do have them available in scripts directory for both OSX and Windows.
These scripts are capable of building the installer packages for both operating systems.
For OSX you need to have x-code installer to use the package builder.
For windows you need nsis to build the installer files.
On windows after build a release you just drag/drop the nsis-4.7.txt file into nsis and the build will run
adding the needed libraries. Ofcourse the nsis file is a bit specific to features/libraries added and the location
and version of the QTSDK, but it's pretty simple, just edit the text file.
For OSX it's pretty much the same, except that you need to run : run macdeployqt LibreCAD.app
so it will add the needed libraries to the final LibreCAD package. (see packagebuilding-howto )
The only tricky part of OSX is that the installer will find a LibreCAD installation
and update THAT, so if you compiled LibreCAD and COPIED into /Applications.
It 'MIGHT' want to re-install on your build. So you need to verify very well.
I also noticed that the tags on githib don't always show the correct version, so sometimes I had
to change this to the right version because I believe when people show the help,
it should show the correct tagged build rather then some github number.
Ries
http://forum.librecad.org/Download-LibreCAD-for-Windows-tp5707942p5707963.html
claus82
In reply to this post by K Lowe
Sorry, my bad!!!
Bye!!!
