Drawing lines at an angle
mdanbury
Hi, How do you draw a line at a specific angle?  If I select the option Draw, Line, Angle then all you get if you select the point where you want it to be is a little line at some unknown angle.  Is the only way to do this to draw a line and then use the rotate function?
Regards
Mike
Re: Drawing lines at an angle
Use command line.
In reply to this post by mdanbury
Sorry, I tried to attach a link, but did something wrong. Look in the wiki for command line manual.
Christian
Hello Mike,
Before you start drawing your line, right click anywhere in the icon line below the menu and make sure that the Tool Options is ticked:
Once done, select the Angle line and you should see the Tool Options pop-up:
That will allow you to set Angle, Length and Snap point.
Regards,
Christian
