Error when install from source on linux
11 messages Options
Dima
I have error on install librecad from manual:
http://librecad.org/cms/home/from-source/linux.html
------------------- Terminal message ----------------------
dima@dima-VirtualBox:~/dev2/librecad$ ls
librecad.pro  librecad.sln  res  src  support  ts
dima@dima-VirtualBox:~/dev2/librecad$ qmake librecad.pro
dima@dima-VirtualBox:~/dev2/librecad$ make
cd src/ && /usr/lib/x86_64-linux-gnu/qt4/bin/qmake /home/dima/dev2/librecad/src/src.pro -o Makefile
Project MESSAGE: Found Boost in /usr
Project MESSAGE: Using Boost includes from /usr/include
Project MESSAGE: Using external muparser
cd src/ && make -f Makefile
make[1]: Entering directory `/home/dima/dev2/librecad/src'
make[1]: *** No rule to make target `../../generated/lib/libdxfrw.a', needed by `../../unix/librecad'.  Stop.
make[1]: Leaving directory `/home/dima/dev2/librecad/src'
make: *** [sub-src-make_default] Error 2
------------------------ end message -----------------
System: xubuntu 14.04 64bit
Re: Error when install from source on linux
Nevermind... I see you did run qmake.
I wish I could help...
In reply to this post by Dima
hi Dima,
you should run
qmake -r librecad.pro
or simply:
qmake -r
because the top folder contains only one .pro file from the official repository.
Dima
Unable to collect, after some time the process freezes. Screenshot attached.
screenshot
I only see warnings, which won't stop the build.
The stable ppa will probably be updated within 24 hours.
https://github.com/LibreCAD/LibreCAD/issues/670
There no error shown.
What do you mean with freezing
It is possible to get kinds of freezing if you runs out of memory, or overheat the cpu.
If you added the -j make argument, that could possibly freeze it.
Try without -j.
Scott Howard updated the wiki articles for Qt 5,
and https://launchpad.net/~librecad-dev
Thanks, they weren't showing with default clang settings.
