Errors dxf poliline
Errors dxf poliline
Dima
I have dxf file exported from internet service to dxf. In this file i'm see bugs when zooming polilyne. How to fix line in LibreCAD?  How do I check that the line is closed?
test_svg_to_dxf.dxf
zooming
Re: Errors dxf poliline
sand1024
well, which version of LibreCAD do you use?  It might be that one of versions had similar issue with polylines.
I've tried you dxf on 2.2.2 alpha - and I can't see artefacts there, it seems that the polyline is fine, it's smooth and there are no breaks.
May you test the same file using dev snapshot (located there https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest)?
