Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I usualy export my draws as pdf to send them by e-mail : no problem. Today : I try to do the same but : it prints in black and white et no in colours... Why ? Did I change any setting by by inadvertency ? Could you help me please ! Many thanks in advance. Surfaces.txt (File in French ... sorry !) |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Did you use File->"Export as PDF"?
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hello
Thanks for answering, yes I did use this function. (In File menu or directly with the shortcut : same result..) |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Can you share a test case dxf? by tool box "Upload a file" in the forum composing page.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
(Sorry for the file ... I made a mistake I wanted to upload the dxf file ... Here you have : Surfaces.dxf) BUT : I think I found my problem : the LibreCad 's "exporting to pdf" seems to act differently according to the PC... My problem is on my office netbook only : on my home computer it works perfectly ... It must be due to different versions of dll... what do you think of it ? Can you have a look on my file : the behavior is very strenge while showing the two "cotes" and "cotes_SDB" layers : their color is filling the red lines (layer : "Electricité R1")... why ? Many thanks ! |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
For me the export of the file works fine in both, Windows and Linux.
Maybe you can give some details about operating systems on your PC'S. And if you can post both PDF files, color and b/w, we may find some difference in the file properties. Armin
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Thanks a lot for your message. Here you have : - The "color" : Plan_R1_20150303.pdf - The "Black&White" : Plan_R1_20150303_b&w.pdf Clould you please have a look to the dxf file and try to show "Cotes" layer ? It fills out the curves from the "Electricité R1" layer ... it looks very strenge... Do you have any explanation ? Many tnanks in advance. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
PD : both of my PC (office and home) are on Windows 7...
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
So far there's nothing wrong with your dxf.
since the pdf exporting fails to black/white only on certain machines, it's likely due to local printer settings. I'm not clear how PdfFormat is handled by windows, but is likely linked to the OS default printer. I suggest you to check your printer settings, and make sure your default printer device is not set to black/white. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
OK, thanks.
Yes the office printer is set to black/white, I didn't think it couls be related : the PDF export and the printing... Did you try to show the "Cotes" layer ? If yes : did you see any color filing of the curves ? If yes : what happen ? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
on *nix, it's not related.
On Windows, looks it's Please report back your test results by changing the black/white setting of your default printer.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I cannot change the settings on my office netbook as I do not have any administrator's rights... But it is OK for me : do not look at my problem anymore : I found my problem, so many thanks for your help. About my other problem ? Did you look a it ? Do I have to open a new subject about it ? (as it does'ne seem to be related to it...) |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Color filling of other entities of other layers(splines?), when showing a layer with dimension arrows?
if that's the issue, it has been fixed in 2.0.6, then, upgrading to 2.0.7 would be the solution.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Ok, tanks a lot !
I have to wait to try the new version, but I try it as soon as possible. Le vendredi 6 mars 2015, dxli [via LibreCAD] <[hidden email]> a écrit : Color filling of other entities of other layers(splines?), when showing a layer with dimension arrows? ... [show rest of quote] -- Cliquez vite sur www.comtedechambord.fr ! |
