1 post
I can export bitmaps successfully if the resolution is set to something below about 6, which for a test drawing I'm working with means a resolution of 750x660. If I select a higher resolution, or specify dimensions of a few thousand pixels, I get an empty file produced (not just a white image, but no data, zero bytes). This behaviour is regardless of the export file type.
I'm running 2.0.2 on Mac OS X 10.9.1
