Feature Suggestionn
1 message Options
Feature Suggestionn
achilliesdev
I was thinking one day it would be nice to have the layers grouped. Example Have a primary layer with sub layers under the primary. Kind of like a parent child data structure concept..
Reason why this would be nice is then you could for example create a
Dimensions layer ->
Sub Layers ->
Plan
Elevations
Details
A single sub under the primary would be enough any more would make the coding very complex and would require extension database type handling to keep everything sorted.
Just an idea I do know some coding but my skill set is in database and front end design not in core design coding.
The reason for the suggestion is in a large detailed draw such as a house the layers library gets enormous.
