Fillet Trim option
Fillet Trim option
Christian
Selecting the Trim icon in Modify, the tool option shows a check case that explains: "Check to trim both edges to the rounding".
My understanding is that if I tick into this check case, once the fillet is in place edges will be erased.
Well, it seems to be the other way round: once checked, the edges are not modified; unchecked, the edges are modified.
If my way of thinking is right then a little correction would be welcome.
Regards,
Christian
Re: Fillet Trim option
What version of LibreCAD are you using?
In reply to this post by Christian
It will work as expected in the latest Nightly Build from either branch.
https://sourceforge.net/projects/librecad/files/Windows/NightlyBuilds/
Christian
Thank you ravas,
I forgot to give the version I am using, it is 2.0.9 which I believe to be the latest.
Christian
It's somewhat confusing, but you actually want to use the latest build in NightlyBuilds/2.0
which is 2.0.9 + bug fixes.
Christian
OK, now I just downloaded the version 2.0.9-41 and, you are right, with regards to the fillets it works fine.
Thanks and regards,
Christian
