Hello all!
My name is Daniel and I am looking to contribute to LibreCAD as I can. I was unable to determine how this community handles contributions and was ever hopeful someone could direct me in that matter. Currently I am working off of a fork of master. As a means for example I have created a patch to fix a slight oddity with the SaveAs dialog. After saving a file to a folder (say folder X), closing the program, reopening the program, the default directory would be the directory above X and the file name would be the name of folder X. This patch first removes an unnecessary break in the function QG_FileDialog::getExtension The second part reworks most of the function QG_FileDialog::getSaveFile in order to prevent the above and gives a default name of Untitled (where an incrementing # is added if Untitled already exists) The patch is attached bellow: patch.diff |
In reply to this post by dan@sstrev.com
Hi Daniel,
The file save/modified part needs more care. I'm glad about your willing to work on it. I will apply this patch, and test it. I'm eager to see it main tree soon. As Ries already mentioned, using git by github.com is the easiest way for us to work together. My own repository at github.com is at, https://github.com/dxli/LibreCAD where you can send pull requests for me to test. Thanks! Dongxu On Thu, Mar 29, 2012 at 8:08 PM, [hidden email] [via LibreCAD] <[hidden email]> wrote: Hello all! -- Dongxu Li, Ph.D. www.librecad.org |
Dongxu & Ries,
Thanks for you replies! I am currently learning git & github and have just created an account for the later (username dstrev). I am planing on having a longer term support; but as to how that will pan out I have no clue as this is my first endeavor of this nature! I fully understand the Windows/OSX/Linux pain that can be incurred and have fought before with the save dialogs in Windows & Linux; however I have zero experience with Macs and still no means to test or build for them. I develop in Linux primarily but have a VM of Xp where I do my Windows testing and builds. Currently I am adding boost to my Windows VM to be able to test and build LibreCAD in that environment. As a note I am using 4.7.4 in both Windows and Linux at this point. -Dan |
Dongxu,
I was hoping you could help me understand something; I have been attempting to push the saveas commit from my fork of LibreCAD to yours but upon selection of your fork github adds one of your commits called "printpreview: suppressed debugging messages" to the list after which I can not remove it... This is after following the procedure from help.github. Is this normal or am I missing something?
Hi Daniel,
I feel it's a merge issue. Your base tree is probably not updated to the latest master branch at github.com/LibreCAD/LibreCAD. Try to merge the latest. since the "printpreview" part should be the same in the master branch and in my repository, pull request won't be showing it any more. My way to do it from scratch (please note I'm using my account as an example, and my ssh public key is already registered by Account profile) mkdir -p ~/github cd ~/github #clone git clone [hidden email]:dxli/LibreCAD.git cd LibreCAD #add remote, the official repository git remote add LibreCAD https://github.com/LibreCAD/LibreCAD #update the added remote git fetch --all #checkout the master branch of the remote to a local branch named "upstream" git checkout -f -b upstream LibreCAD/master git checkout master git merge upstream git push now, do some development in my own branch, commit the changes, and keep it updated: git checkout upstream git pull git checkout master git merge upstream git push here, the upstream branch is from the master branch at LibreCAD/LibreCAD, and the local master branch is linked to my own repository: dxli/LibreCAD. also, the remote "LibreCAD" is used read only. Feel free to ask me any questions you may still have there. Thanks, Dongxu On Fri, Mar 30, 2012 at 5:59 PM, [hidden email] [via LibreCAD] <[hidden email]> wrote: Dongxu, -- Dongxu Li, Ph.D. www.librecad.org |
Dongxu,
Thanks for the help! it seems it is going to take a little bit of time to get the hang of this however I appreciate both your's and Reis' help tremendously! I was able to send a push request with the patch I created a few days ago, tell me what you think! Suggestions are much appreciated. -Dan
