Grid visibility
8 messages Options
Grid visibility
Glenwf
I'm on a MacBook Pro and I'm having trouble seeing the grid.  It is there but I have to try very hard to see it.  Is there a way to made the grid display with bigger dots?
I'm sure the cataracts in my eyes are part of the problem, but until I get those corrected bigger dots for grids would be nice.  The other problem, is the high definition of the display which is great, but makes everything smaller.
Thanks.
Re: Grid visibility
We need to test more with high DPI systems, because our developers are mostly not running high end systems.
I pushed a commit to master branch, attempting to get better grid point sizes. Please spend time to test it. I can not test this feature, because there's no such a system available from my side.
To test the newest git version, please follow the following wiki to build from source,
http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source
Thanks.
Re: Grid visibility
Glenwf
I would love to build the new version, but I've tried this on another program and failed.  It is beyond my skills - I'm a terrible programmer.  Used Basic for years, but was never able to advance to other languages.
I'll have to wait until somebody can do it.  Sorry.  It would take me a week to figure it out and would probably not get it right.  Those instructions are for developers, not a novice and to make them good for a novice would make them so cumbersome.
Would love to help and this program deserves the effort.  Thanks for your efforts.
I'll continue to use LibreCAD because it really does a great job.  I can read manuals, unlike a recent complainer on this list.  Those manuals are great also.
Re: Grid visibility
achilliesdev
Hello Glenwf,
May I ask which Mac book Pro you are using and  which OS you are running?
I am a Mac user with some development knowledge but I am still running Mountain Lion OS. If you are also on Mountain lion I will work on compiling the change the Dx has added and then try and create a DMG of it so that you can try it out.
Also another question for you is what is your colour scheme?
I use black background with high contrast colour for grids and other settings. This is easier on the eyes in regards to a white background and for me makes things easier to see.
Re: Grid visibility
In reply to this post by Glenwf
Please register a wiki account, and help improving our user manual.
Re: Grid visibility
Glenwf
In reply to this post by achilliesdev
I am running a MacBook Pro - Model A1286,
Processor  2.3 GHz Intel Core i7
Memory  4 GB 1600 MHz DDR3
Graphics  Intel HD Graphics 4000 1024 MB
Software  OS X 10.9.5 (13F34)  I think this is Mavericks.
Version: master
SCM Revision: 2.0.5-1-g0aff191
Compiler: Clang 5.1.0
Qt Version: 4.8.6
Compiled on: Aug 15 2014
And, yes I will look at possible improvements for the Help Manual if I see anything as I try to understand it.  Fresh eyes are good to pick out details.
BTW, I am using black on white background because I didn't like the white on black background.  I can give it another try.  I'll look up that setting and see if I have it like you mentioned.
Re: Grid visibility
achilliesdev
OK I am still running Mountain lion which is has some issues compiling the newest version. Where I live it is expensive to down load large files but will work on upgrding to maverick.
In the mean time I will compile to the master and see how it goes.
As for the colours I use black background, primary line colour white but I use layers very heavily and use high contrast colours for lines. When I print I select black and white print only since some of the colours do not show up on white paper. If I want to print in colour I then change the layers to colours that will show up on white.
Here are my settings from top to bottom of the LibreCAD>Preferences>Appearance Colours
#000000
#5afffb
#3F3F3F
#edf404
#739373
#04f4ca
#04f4ca
#00FF00
Try those settings and let me know what you think about them. I find them easy to see.
Re: Grid visibility
Glenwf
Will give it a go.
Thanks.
Printing was one of my concerns using B/W, so your experience is useful.
