Hatch dont work on my w10 64ARM
Rotnei
Hello!! I'm new to cad libre. I can't use anything related to the hatch, I don't have any window after clicking on the icon. The other functions apparently work fine. My PC is a 64bitARM w10. I haven't tested it on a normal 64bit w10 yet.
Re: Hatch dont work on my w10 64ARM
After clicking on the icon, select the object(s) to be hatched, then close the selection with Enter, and the window appears!
Or select the object(s) first, by single click(s) or by pulling up a frame around them, and then click the icon.
Rotnei
Thanks. I thought it was similar to autodesk, but to make a hatch you need at least 3 complete and exact lines (only drawn for this function) closed... Am I right or is there a simpler way?
Yes, you must have a (precisely) closed contour to get a hatch. No gap or overcrossing at the corners. You also can't just click into the wanted area, you have to select the shape elements.
Sorry, not as advanced as autodesk.
