Hatch irregular area
11 messages Options
Bebbspoke
Hi Peoples,
I have perused the forum & tried to rtfm (as & when I could find such).
Please could someone advise or supply links to assist; -
The file attached - as developing stencils for an old motorcycle front numberplate.
The hatch / fill the irregular ("hand" drawn) lettering appears inverted in areas...
Below is link to file as it is too large to post.
https://www.dropbox.com/s/bn3l1pecc8yqbkg/blade11wkg.dxf?dl=0
Please - I do not expect or wish appropriate correction(s) applied...
but would hope to have an explanation of how to correct it for myself!
Many thanks,
Re: Hatch irregular area
Does it look like the examples in this issue:
https://github.com/LibreCAD/LibreCAD/issues/826
Then using the latest version can solve your issue.
You'll find it here: https://github.com/LibreCAD/LibreCAD/releases/tag/latest
Bebbspoke
LordOfBikes - thanks for your msg - Yes! that is exactly the problem - nested closed contours...
Now running latest: -
Version: 2.1.3
Compiler: GNU GCC 4.9.1
Compiled on: Sep 23 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
System: Windows
but problem remains...
Please advise 'cos I'm baffled!!!
Cheers.
PS - "LordOfBikes" - I ain't no lord - but have a reputation with my Ariel Sq4 which I've owned for over fifty years....
Sorry, I was to vague, 2.1.3 from 2016 is not latest.
It is labeled latest because it's the last official release.
What I mean with latest is here:
It is pre-release, but its release is coming soon and it is safe to use.
It will show version 2.2.0-rc4-23-ge3fae3dc compiled on Nov 4 2022.
This version should have the fix for your issue.
PS - I'm not a lord too, I'm just the owner of a LordOfBikes
In reply to this post by Bebbspoke
If the latest LibreCAD doesn't solve the problem, as a workaround look here: https://forum.librecad.org/filling-areas-and-exclude-parts-of-it-td5715760.html#a5715761
Bebbspoke
LordOfBikes & Dellus; -
now using: -
Version: 2.2.0-rc4-23-ge3fae3dc
Compiler: GNU GCC 12.2.0
Compiled on: Nov  4 2022
Qt Version: 5.12.11
Boost Version: 1.75.0
System: Windows 10 (10.0)
This clears the reversed hatch/fill issue at most zoom levels
however the issue still occurs particularly when zooming out.
I have not tried Dellus's work-round as yet as can live with
the zoom limitations...
Thanks both for your assistance.
Cheers, John
I assume, that differences between limiting contour and the hatch are inaccuracies of the drawing unit.
So I think that shouldn't matter, if they even exist at all.
Especially at high zoom levels the entities on the screen may not exactly match the underlying math.
That means when you look at the zoom level, the appearing gaps are presumably a fraction of the whole part.
At an appropriate scale the gaps will be invisible or not existent.
I think Bebbspoke means something different.
Here an example with an exploded and hatched hollow text in various zoom levels:
As far as I have tested it is not visible when printing to paper or pdf.
Bebbspoke
Yes folks - Dellus has reproduced and demonstrates the issue to which I refered...
It seems only present as zoom out is applied and as shown varies as per level of zoom.
Cheers, Bebbspoke,
Dannytechpro89
Hi all,
Thanks for confirming that nested closed contours were the root cause — that makes sense.
However, after applying the suggested fix, I’m still running into an issue. The hatch now behaves better in some regions, but I’m noticing:
* A few inner contours are still being interpreted as separate boundaries rather than holes.
* In certain areas, the hatch either skips small segments or fills regions that should remain void.
* When I check the contours, they appear closed visually, but I suspect there may be tiny gaps or overlapping segments.
Is there a recommended way in LibreCAD to:
1. Detect micro-gaps or duplicate entities automatically?
2. Verify contour direction (clockwise vs counterclockwise) for nested boundaries?
3. Clean the geometry before applying hatch (specific workflow or tools)?
I’d appreciate any clarification on whether this could be a tolerance issue, contour orientation problem, or something else I might be overlooking.
Many thanks again for the guidance — I’m keen to understand this properly rather than just patching it.
Cheers.
Danny<br>
Interested in CAD workflows, geometry & computational drafting.<br>
Occasionally sharing tools & notes here:
areaofirregularshapescalc.com
Hi Dannytechpro89,
Could you upload some dxf files with those issues?
Please also try our development builds:
A new algorithm for solid fills and hatches are still being developed in the master branch, but hopefully, new features can be added with improved robustness.
Dannytechpro89 wrote
Hi all,
Cheers.
