Everything you do is stored it seems, I import a block to ghost it and check part to part dimension, I draw a line or a circle - it just all adds up and stays regardless if I delete it or not.
You can see the difference in file size after 'cleaning' it through Draftsight (dwg or dxf save doesn't matter).
Very happy with Librecad otherwise.
Another question please, I have around 1000 4mm holes (rivet holes) and would like to change the size to 3mm, is it possible to do this in bulk? Would save a few hours!
