How do I save a block without all other blocks?
karpsj
Hello all,
I am discovering that when I save a block from the block window, LibreCAD saves *all* other blocks as well.
Is there a way of preventing this?
Thanks!
Re: How do I save a block without all other blocks?
I'm not sure if I understood your issue correct.
What you describe is the intention of blocks. Blocks are created and stored in a table inside the drawing.
When a block is inserted, only a reference to the table is inserted in the drawing.
But it is possible to change rotation and scale of the block with each insertion.
So when you change a block in the block editor, all other insertions of the block will be changed too.
When you want to modify a block for different insertions, I recommend to explode the block in a free area of the drawing and then create a new block with different name to modify.
Find more details about block operations in our manual:
https://librecad.readthedocs.io/en/latest/guides/blocks.html
karpsj
LordOfBikes wrote
I'm not sure if I understood your issue correct. What you describe is the intention of blocks. Blocks are created and stored in a table inside the drawing. When a block is inserted, only a reference to the table is inserted in the drawing But it is possible to change rotation and scale of the block with each insertion. So when you change a block in the block editor, all other insertions of the block will be changed too. When you want to modify a block for different insertions, I recommend to explode the block in a free area of the drawing and then create a new block with different name to modify. Find more details about block operations in our manual: https://librecad.readthedocs.io/en/latest/guides/blocks.html Armin
Hello Armin,
My ultimate goal is to insert the block into a different new drawing (let's call it d02).
Here is what I do:
  • In an older drawing (let's call it d01), I open the block that represents a machine part I want to use in a drawing.
  • When the block window opens, I save that. I see no layer, no other blocks in this block window.
  • I then go to the new drawing (d02) and import that block.
  • In d02, when I look into the block area, I see all the other blocks from d01...
    Thanks!
  • Reply | Threaded
    OK, then follow the instructions in the manual.
    Don't open the block, use the disk symbol in the block list to save the wanted block in a new file.
    Then  import this file with the block in the new drawing and make block modifications there.
    karpsj
    Worked! Great!
    Thank you so much!
