How end command in Command file?
eengebruiker
I am able to draw some elements in LibreCAD using a command file. I do not know how to end a command. If I do one line, the line is drawn but LibreCAD waites for the next point which is not in the script.
After drawing a line, I can draw a circle with center point and point on the circle. In this case the Line command is ended to be able to draw the circle but then LibreCAD waites for a next centerpoint, which is not in the script.
Etc. I am searching for a proper way to end the sequence from the command file.
Re: How end command in Command file?
To enter a point for input, just enter coordinates:, for example
0,0
@10,0
@10<45
I am not aware of a generic way to end an action. Properly, it's good to add one.
eengebruiker
Thanks. I am aware of the way to input coördinates.
I found an example on internet where 'kill' was used. I tried it but don't know if it is correct. The result in de command window was like this:
Hope others have suggetions. Maybe someone can tell what kill is really for. I found that it ends multi command lines but don't now if that's all.
It is useful to include the source: https://docs.librecad.org/en/2.2.0_a/guides/cmdline.html#multi-command-input
li
Command: li (line2p)
0,0
@10,0
@0,10
@-10,0
c
k
Command: k (kill)
Command: k (kill)
I noticed the multi Command: k (kill) lines the other day and intended to report it as a bug.
eengebruiker
Ok, kill is the way to do it.
Commands can have 2 levels so replication of kill might be necessary. It's just that I don't have to see it.
