How should PDF Export work?
3 messages Options Options
BenW
I need to create a PDF of my drawing. When I attempt to do so using File>Export>Export as PDF, I get a new file Print Preview for[filename].dxf* .
I am using Version: v2.2.1.1 on Windows 10
Any suggestions appreciated.
Re: How should PDF Export work?
you can continue with File > Print (again), after seeing and adjusting print preview.
Alternatively, you may also try File > Export > PDF, or even command line like:
*nix:
$ librecad dxf2pdf foo.dxf
BenW
Export a second time worked. Thank you.
