How to move entities
Allen
Please explain how to "move", "scale", or "rotate".
I can get the entity selected and that's as far as I can go.
Thanks
Re: How to move entities
Willem
Hello Allen,
After you have selected the entity to move or rotate, click the green, most below, pictogram on the left side and follow the instructions.
Regards,
Willem
Allen
In reply to this post by Allen
Willem,
Many thanks, it's simple when you know the steps.
Allen
It's equivalent to pressing the Enter key.
so, either the right pointing arrow button in cad toolbars, or Enter key.
Allen wrote
Willem,
Allen
th3pr0ph3t
The use of this command is not intuitive. My first impression was that it was not implemented.
When the command line prompts "Command:" the user is actually expected to click on the Continue Action button (>>) and that's almost impossible to guess.
A better hint is required, maybe pressing the enter key should equal to clicking on Continue Action so the command can proceed to "Specify reference point" and then to "Specify target point".
[EDIT] Er... scratch that. I tried the same in v2.0.0beta1-29-g7530c62 and it now works as expected.
The mv command now works as it should.
pwright2
I still think is it pretty counter-intuitive (or, at least, not like anything else that I use).  But if someone puts a paragraph in the manual explaining this (fairly early, I would suggest) it is quite workable.
-----Paul-----
