How to select a layer from the command line
Kurt DJ
Is it possible to select a layer from the command line?
I have a list of layers and I want to change the active layer with a command in the command line.
Re: How to select a layer from the command line
eengebruiker
I have the same question.
eengebruiker, I don't know what you thought about https://forum.librecad.org/Introduction-tp5728328p5728337.html which is a call to make user interface, including commands, more user accessible.
Maybe you could add the command to the LibreCAD code, eg https://github.com/LibreCAD/LibreCAD/commit/64aa33a24de97adfa5424b1fd6bcbd12138e007b
say:
        // set layer
            {{"setlayer", QObject::tr("setlayer", "set active layer")}},
            {{"sl", QObject::tr("sl", "set active layer")}},
            RS2::ActionLayerSet
Would require commands and ActionLayerSet to be available.
Hmm, it's more complicated than this. In the Layer widget when you click on the layer it sets the layer in the list, so the layer in the list must be identified.
There might (possibly) be some clues in this fork/branch: https://github.com/emanuel4you/LibreCAD/tree/developer
sand1024
In reply to this post by Kurt DJ
this is possible, yet in 2.2.2-alpha branch (not in production yet).
I've added a couple of commands exactly for that:
Commands for layers creation and activation
Two simple commands were added to let management of layers via script file (this addresses #2092)
cslayer - activates layer with specified name
cnlayer - creates and activates layer with given name
More information about is might be found there - https://github.com/LibreCAD/LibreCAD/pull/2114
Development snapshot for 2.2.2-alpha is located there - https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest
eengebruiker
Hope my lines do not look too critical. In fact I am exploring the boundaries.
I read the replies https://forum.librecad.org/Introduction-tp5728328p5728337.html but do know what exactly to answer. It feels like I have to be half a developer to be able to use LibreCAD.
Some things might be easier than I think. I saw files (somewhere) where lines like the following fit in. Guess I can figure this out.
        // set layer
            RS2::ActionLayerSet
But doesn't that require a C++ compiler? Although this is not completely alien to me, I do not intend to go that far to be able to use LibreCAD. I am a user in the first place, not a coder. I like VBA, GoogleScript, AutoLISP, Clojure (just toying with that). As you can see from this, I do not make applications. (I do not compile with an exception for Clojure.)
But (as written above) maybe it's easier than I expect.
eengebruiker
With exeperience in AutoCAD it's easy to ask for (even) more when solutions or new developments are released. There's unreasonableness in this so I am a bit indecent I guess.
As far as I saw this does not come with the possibilities to set properties of the layer (plottable, color, thickness, etc.).
BTW, thanks for replying.
