Hi All,
Need your help. I many times facing problem to move up/down an entity over another of an overlapped entity as below. Below are two lines, one above another. The dotted lines is above the solid one, and it is longer. So when I want to select the solid one, I could not.
I see there are four tools that function to move one from above to below. Unfortunately so far I have never succeed to use. Is that tool used for that purpose?
Is any one have tip and trick how to do as I mentioned? Normally I just delete the upper one and re-create the shorter one so it is above of the longer one. But I believe that is not the solution.
Best regard,
