How to use Chinese drawing in this software
6 messages Options Options
locacyan
This post was updated on Jul 23, 2023; 12:57pm.
I'm using librecad now, but I can't use Chinese to draw in the software
Because the software does not have a Chinese font file, and the software uses a font in the format 'lff', I browsed the Internet for a day and only found a ten-year-old font, which cannot run.
How can I use this software to draw Chinese now?
(librecad version: 2.2.0.1
System version: Windows11, 22h2)
Re: How to use Chinese drawing in this software
This post was updated on Jul 26, 2023; 3:01pm.
Chinese font support is needed. Please note LibreCAD uses vectorized fonts lff. A tool is provided by librecad to convert from ttf to lff.
WenQuanYi Chinese fonts can be found in the discussion of issue 1243
https://github.com/LibreCAD/LibreCAD/issues/1243
You may also download the old release of 2.1.3 which has WenQuanYi fonts included.
locacyan
Thank you very much for your reply, the font you gave is available, and i found the tool you said
ShaunKc
1 post
In reply to this post by locacyan
You can download ttf2lff for windows from here: ttf2lff_1.zip
For my experience:
I download Noto Sans Traditional Chinese Font from google font
And use ttf2lff tool to convert NotoSansTC-Thin.ttf to notosantc-thin.lff
ttf2lff <ttf file> <lff file>
#The llf file name must be lowercase otherwise it will display a diamond when you use it.
Copy notosantc-thin.lff to C:\Program Files (x86)\LibreCAD\resources\fonts
#Tip
Set the Word Attributes Pen Width 0.13mm or up to you
We should add to our setting menu a way to download more fonts.
As I suggested in GitHub:#1243
I recommend to add a link to https://dokuwiki.librecad.org/doku.php/community:fonts#additional in the Help menu and maybe a hint in Application Preferences Paths section? Or even in the MText options dialog?
