The attached screenshot is taken from AutoCAD 2013.
The cut to the radial lines was made by selecting the ellipses as cutting entities and then, with a few clicks and a few selection areas (to cover many lines at once), I selected the lines to be cut. This way you can cut all the lines with a reasonable number of clicks. Everything took less than a minute.
My problem is that I can't find a way to do the same with LibreCAD. I can only do this one line at a time by splitting the line into two pieces (using one of the ellipses as the cutting entity) and then cutting off the remaining part (using the other ellipse). The way I found to do it is really slow, is there any way to do it like in AutoCAD?
I'd really like to stop using AutoCAD and definitely switch to LibreCAD, but things like that keep me trapped in non-free programs.
Please, any solution is welcome.
Thank you very much.
