Inch marks in dimensioning?
4 messages Options Options
DEValken
Is there a way to get UM indicators (feet and inches specifically) added to my dimensions? I don't see a way other than manually editing each one. I'm using 1.0.2 (Ubuntu 12.10) if that matters.
Thanks for any help- and thank you even making this question possible.
Dave
Re: Inch marks in dimensioning?
hsrai
What is UM?
Anyway, if you want to see dimension text as 2'-3" you need to set "main drawing units" as "inch" and "Length format" as "Architectural" from Edit -> Current Drawing preferences.
H.S.Rai
H.S.Rai
Siprex3D
Hi
I don't know what "UM" is.
May be micrometer?
But I for my part, would like the length unit to be written on the dimension line.
In other way I would like replace "??" by the unit set up in the preferences
DEValken
In reply to this post by DEValken
UM- Unit of Measure. Sorry if my terminology is incorrect.
We do a lot of small drawings where the largest item is only 4". When I used the fractional format, it doesn't input the mark ", and I hate seeing the 0'-4", 0'- 3/8", etc.
Right now I edit these manually, or make a blanket statement about "All dimensions in inches" kind of thing.
Thanks for the responses...
Dave
