Incomplete Drawing Printout {Solved]
MisterEd
SOLVED!  Line width setting incorrect for layer.
I just printed out my first LibreCAD drawing and the majority of the
drawing is missing. It looks like it only printed out the elements I added
to the drawing today. The "Print Preview" shows the entire drawing. ???
Is this a layering issue possibly?
Any suggestions welcome!!!
Mister Ed
Re: Incomplete Drawing Printout
This is probably related with your other issue.
Standard line width is currently 0 in LibreCAD. This is to keep line thickness independent from zoom level.
Depending on operating system and printer driver it happens, that line width 0 is printed very faint or not at all.
So try to change line width to an appropriate value, as you would select a pen with the desired thickness.
When you did not change entities line width, which is 'By Layer' default, it is enough to change line width in layer properties.
In reply to this post by MisterEd
Depending on your printer, or printer software/driver, entities with linewidth 0.00mm, or Default, which is the same, may be printed very faint or not at all.
The same applies when printing/exporting to pdf, depending on the pdf-viewer app. Some such apps allow a choice how to handle hair lines.
Print Preview always shows lines 0.00mm wide.
Linewidth of entities is defined either individually by pen properties when drawing them, or as an attribute of the layer they reside on (pen property "By Layer").
See the manual https://librecad.readthedocs.io/
MisterEd
Thank you for the explanation LordOfBikes and dellus!
