Incorrect dimensions
2 messages Options Options
wenmoose
I slowly learning to use LC to draw a simple office building remodel.  Design is done and looks very good, but I can't get the proper dimensions.    I drew the plan so the distance between two tick marks is 1'.  I am unable to get the proper length dimensions.   I've learned how to do the dimension lines and formated the text, arrow head size, offset etc.  Now if I could just get the proper dimensions to show.  I have set "architectural" length format.  General scale 1.   Now when I dimension a 30.5' wall,  LC spits out a length of 2544' 0".     How did LC come up with 2544' when I meant it to be 30.5?    It must be a scale issue that I'm not able to configure properly.   Any help is certainly big-time appreciated.  Randy
Re: Incorrect dimensions
Have you not found and read the thread of your former query? https://forum.librecad.org/Dimensions-not-correct-tp5726100.html
What do you mean with tick marks? The grid? Out of the box the grid changes automatically with zoom level. If you want it to be fixed you have to set it accordingly in Drawing Preferences.
You can leave General Scale at 1 if you edit the sizes of text, arrow head, offset manually. You could leave these as out of the box if you set general Scale according to the intended print scale, for example for 1:48 it would be 48.
Lenght factor normally has to be 1, except for special purposes.
You can provide your drawing here for inspection, I might then be able to help fixing the settings:
I recommend to have a look into the manual to learn about basic setup of a drawing.
