Installing LibreCad in a Slackware distritution
moonstroller
Hi Everyone. I tried installing the LibreCad in xubuntu 14 and had problems. I installed it in Slackware 14 and it installed ok after dl'ding and installing the Muparser lib.
Not sure what I did wrong but the program did not install in the system applications directory, so is not in the normal path. It installed in the User directory. Once I found the bin, it was simple to make a launcher and start using it.
However. I would like to install it in the normal system path for GUI programs in the slackware environment. I would also like to have it registered in the applications menu of the Xfce window manager I'm using.
Any help with any of these will save me a lot of researching time which I just don't have anymore (getting old).
Thank you in advance.
moonstroller
Re: Installing LibreCad in a Slackware distritution
Hello moonstroller.
At the end of LibreCAD (LC) build process the script
"scripts/postprocess-unix.sh" is executed, this script installs LC in the user directory
You must modify some things:
1. in file "librecad/src/src.pro" remove or comment line #53
       QMAKE_POST_LINK = cd ../.. && scripts/postprocess-unix.sh
to separate build/install steps, then the build process change to:
~> cd "LC-souce-code"
~> qmake -makefile librecad.pro "CONFIG+=release"
~> make
2. modify the file "scripts/postprocess-unix.sh" to change/add installs paths,
the install process change to:
~> sudo scripts/postprocess-unix.sh
The required files for that are in "desktop" dir.
If you are familiar with RPM packages this link may be useful:
https://build.opensuse.org/package/show?package=LibreCAD2&project=home%3ARallaz
moonstroller
Thanks. I finally got it working by setting a link to a lib file. I forget which one.
Right now, I'm having problems with the input format for architechual units.
I've tried 2'-2 1/2", 0'-0" and all variations but the only thing that works is 2*12 + .5, 0
Any advice?
moonstroller
Rallez, I'm sorry to bother you but I lost the program after the hard drive died. I put a new SSd in and it's zooming. :)
I forgot how I got the progam working.
I downloaded the source for version 1.0.2.
I did a qmake.. no problems. make... had to install MuParser.. no problem.
Tried make again.... compiled and installed ok.
But.... it's not a 64 bit program so it won't run on my slackwware 14.0 64 bit OS...
any ideas?
If you build the program in a 64 bits system with a compliler that support 64 bits and
link with a 64 bits version of muPArser and Qt, is a 64 bits program.
You have installed qt development files for 32 & 64 bits ?
moonstroller
Only for 64 bit there is a 64bit qt section:
/usr/lib64/qt/include/
will I need 32 bit includes for qt?
If so there is a multilib patch I can d'ld and install from alienbob.
John.
