Land Survey Diagram
Land Survey Diagram
I have a few questions to draw a land survey diagram.
1) The coordinate system uses 0 degrees at the top and turns clockwise. How can I adjust the coordinate system?
2) Where do I enter the height data?
3) How do I generate contour lines from heights within the survey area?
Re: Land Survey Diagram
Librecad is a pure 2d-cad. It can't handle height data and so can't generate contour lines.
The coordinate system can't be adjusted either. Sorry.
perepujal
could you attach a sample of the data you get?
and if possible the output you need to provide with that data?
Input:
* Stadia_Survey_V3.xlsx
* lot boundaries - not provided
Output:
