Until recently, I could place texts in drawings and with all measurements (e.g. Alined, Linear, etc) the numbers were shown. However, now all text and numbers have disappeared. Also, in the MText window, I can't select a font. I'm Using Fedora Linux 34. I realize this is very little info, but can somebody please shed a light on this? Thanks |
Is the missing text shown as boxes only? Then View - Draft is activated, switch it off.
Also when very small on screen and hardly recognizable anyway, it is simplified to boxes to save computing power. Can't select a font? What do you mean? It seems to have no effect to change the font? Try different fonts, some seem to make no difference, don't know why. |
No, really all texts and numbers are gone. Not even shown as empty boxes.
What I mean with "can't select a font" is that in the top-left corner of the MText window, there's no font listed. At all. The drop-down menu where you should be able to select a font, shows nothing and clicking the down-arrow doesn't show a list of alternative fonts. I uninstalled and reinstalled LibreCAD and noticed that the -font package is installed. So that's not the cause of the problem. |
This sounds like fonts location is not found.
As you already recognized, there is not much valuable information in your request. Before I start guessing, please provide more information about how you installed LibreCAD. Did you build yourself or used a package manager? What is the exact LibreCAD version from Help->About window?
I installed LibreCAD using the dnf package manager.
The exact version of LibreCAD is: Version: 2.2.0-alpha Compiler: GNU GCC 11.2.1 Compiled on: Feb 1 2022 Qt Version: 5.15.2 Boost Version: 1.75.0 System: Fedora 34 (Xfce) I hope this gives more clues. |
When it worked with older packages before, I assume that the maintainer of the package has changed anything related with the fonts location.
Or Fedora has changed its common folder structure, so the coded search locations don't match anymore. On Linux LibreCAD is looking at some common places for the fonts folder containing the LFF files. I must look into sources for these places. So you can contact Fedora and/or the packet maintainer about this issue. I'm not familiar with Fedora and have to search for possible cause, which may take a while. You can also search for the fonts folder, e.g. in /usr or /opt. When you have found the path, you can enter it in Application Preferences => Paths => Fonts. Possibly you must restart LibreCAD after applying the path, to make it work.
I looked for the font directory and found this:
/usr/share/doc/librecad-fonts]$ ls LICENSE LICENSE_Apache2.txt LICENSE_GPLv3.txt /usr/share/doc/librecad-fonts]$ but maybe that's not the actual fonts location, although this: $ find /usr/ -name librecad-fonts /usr/share/doc/librecad-fonts $ doesn't show any other location. It turns out that there's no maintainer listed at pkgs and Package Search is unavailable. |
librecad-fonts is not the folder LibreCAD searches for fonts, seems to be added by Fedora.
The librecad-fonts package info says that fonts are located at: /usr/share/librecad/fonts/ That's the right place where we look for font files. So you should check - if that folder exists - if there are a bunch of lff files - if it is readable for everyone, at least -rw-r--r-- Alternatively we have AppImages for Linux, starting with 2.2.0-rc3, which should run on Fedora too. See https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.0-rc3 for last tagged version or https://github.com/LibreCAD/LibreCAD/releases/tag/latest for binaries of latest changes.
Ok,
I checked and find: $ ls /usr/share/librecad/fonts/ amiri-regular.lff italicc.lff romant.lff azomix_i.lff italiccs.lff scriptc.lff azomix.lff italict.lff scripts.lff cursive.lff kochigothic.lff simplex.lff cyrillic_ii.lff kochimincho.lff standard.lff gothgbt.lff kst32b.lff syastro.lff gothgrt.lff lc_opengost-ar.lff symap.lff gothitt.lff lc_opengost-br.lff symath.lff greekc.lff OpenGostTypeA-Regular.lff symbol.lff greekcs.lff OpenGostTypeB-Regular.lff symbol_misc1.lff greek_ol.lff romanc.lff symbol_misc2.lff greekp.lff romancs.lff symeteo.lff greeks.lff romand.lff symusic.lff iso3098_i.lff romanp.lff unicode.lff iso3098.lff romansi.lff wqy-unicode.lff iso.lff romans.lff $ and the files are all -rw-r--r-- I'll try an AppImage. Edit: the AppImage shows text fine. So something seems to be quite wrong with the dnf-installed package. |
I'm running Fedora 36 right now and had the same problem.
Here is what worked for me: adding "/usr/share/librecad/fonts" to Options->Application Preferences->Paths->fonts hope this helps anyone still having this problem... |
Many thanks @5eppl for reporting this workaround!
There was just issue #1543 created, which addresses this too. It turns out, that Fedora uses 2.2.0-rc3 code which was tagged in Nov. 2021. In Jan. 2022 a user reported issue #1488 which is presumably the source of this problem. This issue was fixed on Jan. 6, so when Fedora will update their source, it will be fixed. I'll get in touch with the Fedora maintainers to fix this.
