LibreCAD Users Manual Update
3 messages Options Options
This post was updated on Nov 28, 2019; 11:00pm.
Kinda hard to follow when the Menu doesn't match the User Manual. [ Edit: Much of the wiki material is very dated and instructions don't work with current version but the examples are better than the manual. Added links to LibreCAD User Manual for LibreCAD ver 2.2.0. ]
https://wiki.librecad.org/images/8/8e/Lc_coorddf.png
Can anyone offer a quick conversion? I'm specifically interested in Viewing and Changing Line Properties. (A circle has more than total length and current layer.) I'm thinking it's Tools, Modify, Properties but I can't see anything after that.
Re: LibreCAD Users Manual Update
Found one: Tools, Modify, Properties, Click object
Right-click context menu properties item seems a bit strange. Execute it then click on object - I was expecting the other way round.
aman
This post was updated on Nov 28, 2019; 2:14pm.
You can always use command line, commands were listed some where in the wiki, just now bit too busy.
Select item, click command box or press space bar, command: ma to modify attributes.
EDIT: properties, not attributes, then the command would be: prop
Properties can be selected also from left side panel modify-menu (+) => Properties.
