LibreCAD and Artificial Intelligence
usuario
Thank you very much for all the work you do on LibreCAD.
I am not sure if this is the right place to raise the following question; if it is not, I would appreciate it if you could move the topic to the appropriate section.
Is there currently any plan, proposal, or discussion regarding the implementation or use of Artificial Intelligence (AI) as a feature for LibreCAD users?
For example, AI-assisted drawing, geometry generation, design assistance, or other CAD-related workflows.
Has anyone experimented with this or thought about possible applications?
Thank you in advance for your time and attention.
Kind regards,
Usuario
Re: LibreCAD and Artificial Intelligence
sand1024
hm.. first of all, what for? Potentially it might be possible to create an agent that will use core of LC - but it will require quite a significant internal refactoring to provide clear API that may be invoked by the agent.
I remember that somewhere in forum or on tracker in GitHub it was mentioned that somebody tried to create agent that will product dxf that may be opened by LC.
In reply to this post by usuario
Our internal API was not designed to handle comprehensive text instructions for major features;
A layer is needed between the LLM output and our API;
One solution could be python API, so LLM should be generating python instructions to get drawings;
Direct DXF generation could be enough for simple drawings though.
In my own opinions, python should be the way to go.
usuario wrote
Kind regards,
Usuario
